dan222000 »
https://forums.nicoclub.com/dan222000-u59798.html
Tue Nov 04, 2008 2:46 pm
I just completed installing a complete front and rear z32 conversion on my S14. I installed z32 front and rear calipers, rotors, & pads. In the rear I also did the Z32 e-brake conversion with R33 cables. I also installed a new Z32 brake Master cylinder from FRsport. The only problem i'm having is the bleeding process. I didn't bench bleed the master cylinder. I tried bleeding the brakes 3-4 times and I also bleed the master cylinder at least 3 times. The problem i'm having is that I build pressure but after letting the brake sit for a minutes and when I got to hit the brakes the pedal goes to the floor after the second pump I build pressure. The only thing that I think might be the problem is that I didn't bench bleed the master cylinder and I also found that I installed the rear calipers backwords with the bleeder valve on the bottom. I believe that is my problem but can anyone confirm this? I haven't had a chance to bleed the brake system again since I switched the rear caliper to the correct position. Can anyone confirm that with the rear caliper installed backword that I will never get all the air out of the system.
Thanks,Dan
