nope not yet, i took the cap off the distributor to check for oil and theres none.ThatSRguy wrote:did you get it started?
i dont know if the starter is bad, would that cause my car to shut off while it was already on/driving?nyc240sx wrote:take a metal pipe have someone crank the car and bang on the starter with the pipe while he attemps to start it i used to do this on my daily driver when i was broke but eventually time came and i got a new starter..
when the car was on last, i rev'ed up my motor a little and the headlights got brighter when i did that, i was told if that were to happen it means the alt. is still good. should i take it out and get it tested? just to double check?Dittoz7 wrote:Bad Alternator.Meaning It's Running Straight Off The Battery.After A While Battery Wouldn't Be Able To Hold The Charge And It'll Die.
Or
Something Is Creating A Short In Your Electrical System.
Off The Top Of My Head.
