s14 with D2 Coilovers...Wheel-tire question
cardinal
Anyone out there have an s14 with D2 coilovers on it? If you have one, what size rims and tires are you running? I have searched to see if I could find some setups that work for sure, but have had no luck. I have a 97 240 that I want to put on some 18s, but have heard conflicting info on what will work and what will not. Any input would be great. Thanks.
crzycav86
Car: 93 Nissan 240SX KAT
What are the specs of the wheels you're looking at?
If they have a +40 offset, don't even think about it....
cardinal
I tried a set of 8" rims that I think had a 38mm offset and they were rubbing the spring. What do you think I should try??
crzycav86
If it's 8 inches wide, go with an offset of 30 or less.
Chingon
Car: 1991 and 1992 hatchbacks
Width Offset 6" +54 or lower 6.5" +45 or lower 7" +40 or lower 7.5" +34 or lower 8" +30 or lower 8.5" +24 or lower 9" +20 or lower
