S14 Wiring
eng
I'm finally in the process of putting the SR into my car. Here's what I've got for the dash connector:
KA Side SR Side
Anyone care to comment on any errors I've made or additions I should take note of?
Thanks
Fibercus
SR one is for an s14 correct? Zenki or Kouki matter?
Fibercus
nevermind.
eng
Just in case you didn't figure it out, yes it matters.
Fibercus
I have a Zenki SR going into a Zenki USDM chassis, Im going to give this a try then.
I will post an update once im done
Fibercus
Damn, I finished my wiring (f4) but I think my starter is dead... When i turn the key all i hear is a click coming from under the drive side dash (kick panel)
I only have one ground - Battery to Chassis to Intake Manifold. Should i add another to the block?
Perhaps starter solenoid gone bad
Would this cause it to click just once? My battery is full and connection from it are clean... Fuse is OK, anyone recommend what I should to test it? I tried instructions from FSM (exactly as in image) but was sparking like a mofo.. and im positive im following the pic.
BTW My s14 zenki was auto b4 the swap and I am using the KA harness.. DO the transmission sensors (not being hooked up) have an ability to disable starter? I also tried it with my SR harness with it plug into the SR sensors... I dont have KA sensors to use at this time.. that might be it to im guessing. Anyone have some input?
UPDATE: Tried ground route, added nice block ground - nothing, still click from driver kick panel
eng
For the lower harness I just kept the SR one and used the 2 connectors from the KA harness that are right below the fuse box.
If you use the KA lower harness you have to swap over at the very least the speed sensor. I'm not sure about the others.
The clicking once could honestly be just about anything. In my case the first time it was because the NEUT connection wasn't solid and the ECU thought the car wasn't in neutral so it would just click once and not try to start the car.
HotWIRED
Did you jumper the neutral switch interlock that by the engine fuse box?
Fibercus
HotWIRED wrote:Did you jumper the neutral switch interlock that by the engine fuse box?
BINGO, did it last night. Starter works fine. Today Im going to hook up my wiring and see if shell start =D Hopefully ill have a start up vid to share
DrftDmn
Car: Alot of things
I have some Questions about the wiring , Can you e-mail me , [email protected] thanks
Fibercus
DrftDmn wrote:I have some Questions about the wiring , Can you e-mail me , [email protected] thanks
Im updating on another thread now, send me an email: [email protected]
