EfiniRX7 »
https://forums.nicoclub.com/efinirx7-u88113.html
Sun Apr 26, 2009 2:30 pm
SR wire up : Sheet1.
.(pin# on F3 that F4 pins must match to. .COMPONENT F4 PIN Color F3 Color .CONSULT .CEL 28 Orange S30 OR .SCI AX IN 8 G/B S38 G/B .SCI TX OUT 18 G S22 G .CSI CLK 15 G/W S23 G/W ..WIPERS .INT SW 2 L/Y S27 L/Y .INT VR 1 PU S42 PU .OFF and INT SW 41 BR S8 BR .WASH SW 45 P S4 P .Wi Mtr Power 44 LG S5 LG .Wiper Low 42 LG/R S7 LG/R .Wiper High 43 LG/B S6 LG/B ..ECM .IGN SW 48 BR S1 B/R .BATT/CRNT 32 S17 R POWER TO ECCS RELAY .Ignition Coil Rel + when engergised 40 B/R S1 B/R 30 amp fuse .ST SW START Signal 30 OR/L S34 OR .O2S 29 BR S18 BR .Injectors + 40 R/L S1 B/R .Fuel Pump 22 B/Y S11 B/P .VTC 29 BR S18 .IACV AAC 31 B/Y S18 BR .DEFOGER LOAD SW 47 L/R S3 L/R .Pressure Sw Power Strng Extend .Wastegate 29 BR Power to Valve .Pin2 At Valve To ECM .COOLING FANS .RF RL LOW 20 OR/L S41 L/G SR: ecm 19 .RF RH HIGH 26 L/G S25 OR/L for AC pin 10 L/G (ecm 33) .....AC STUFF .AC RLY(to TPR SW) 17 G/Y .AIR CON(Thermo Cont amp) 25 R .IACV FICD SOL VLV(to ac Rel) 37 L/R S44 L/R ...With ECM RELAY on Power at 49 59 at F1 B/W .Power to ECCS Relay through F4 32 ..Boost Sensor .AVCC 24 LG/R .TPRES 39 W .Ground 23 B
I can't seem to get the link to work. I copied and pasted. I don't take any credit for the info here I found it somewhere.
