s14 window motor problem
mmaxeyjr
Car: 1995 s14
Like most s14's (95 zenki) my drivers side window was down all the way and I went to put it up and it would not go up. It happened so randomly. It will not go up at all but passenger window is fine. When I press the window button for the drivers side the amp makes a click noise but the motor doesnt move. i noticed 2 wires coming off the motor that aren't hooked up to anything.
I'm not sure whether it's the regulator, motor, or amp. However since the amp makes that noise, i'm assuming the amp is still good. Also I took apart the little white amp box and the solders on the circuit board appear to be good.
thanks
jlb8434
Car: 1995 240SX SE
I have the same thing with my 1995 240, I just bought it. The Guy i bought it from said that it was the switch, so i took it apart. Moved the little white switch on the CB and the Amp makes a clicking noise too. I took the Amp apart and looked over it, everything looks good, but my driver side window still won't work. Does anyone Know if Nissan used the same motor on any other cars around 1995. I have a Pick and Pull Junk yard around but they dont have any 240's... Go Figure. Any help out there.
S14Juggalo
Car: 95 240sx (S14)
I am having the same exact problem I had a nissan tech take a look at the window amp and window switch for me and did an ohms test on 2 driver window motors (thought it was the window motor burnt so i got a new one) and they are both identical the tech said that my switch was fine and i told him my white amp box was clicking when i try to roll the window up so he checked it and said that the passenger side works but the driverside of the window amp was fried common zenki problems! So i hope that helps your problem cuzi know its irritating my window still isnt rolled up cant find anybody with window amp! If not that and your window motor is the culprit and burnt out i have a good one for sale!
jlb8434
Car: 1995 240SX SE
The Amp looked ok inside and both sides click. I think i'll try my luck and see if I can't get my hands on another AMP then go for a Motor if that doesn't fix it. Good luck with yours
S14Juggalo
Car: 95 240sx (S14)
jlb8434 wrote:The Amp looked ok inside and both sides click. I think i'll try my luck and see if I can't get my hands on another AMP then go for a Motor if that doesn't fix it. Good luck with yours
How the crap do you take the amp apart without distroying it?
jlb8434
Car: 1995 240SX SE
LOL, You really can't take it apart with out messing it up alittle. There is a thread around here that does have pics of it comeing apart that may help.
S14Juggalo
Car: 95 240sx (S14)
Do you have a link to this said thread? Sorry i dont know my way around this forum.
jlb8434
Car: 1995 240SX SE
S14Juggalo
Car: 95 240sx (S14)
WOW thats awesome!!!! Thank you very much bro!!!
mmaxeyjr
Car: 1995 s14
Did you find out how to fix it? My amp is fine but i'm not sure what the issue is because theres no power to the amp or window motor...
S14Juggalo
Car: 95 240sx (S14)
Yeah i saw the thread but i didnt take mine apart yet. So your whole door is dead?
mmaxeyjr
Car: 1995 s14
no my passenger window works fine through my drivers side, also when i hit the button for the drivers side window the amp clicks but no action with the motor at all..
S14Juggalo
Car: 95 240sx (S14)
Thats my exact same problem i ordered a new amp so when i get it and put it in ill let you know what happens.
romero87
Car: s13, s14
i also had the same problem where id hit the window switch and the amp would just click. sometimes it would work tho and sometimes not. acutally worked a few times when i hit the door panel right where the amp was and then it would work. Well i figured out the mystery of mine. I was f***ing with the connection of the amp and the door wiring harness. And the window worked. If i pushed on the plug into the amp it would work. So i just took some zipties and wraped it around the amp and the connection to hold them together tighter. It worked for the night and the next morning but when my car sat in the heat all day the ziptie had strectched so i had to tighten it up a little more and there no more window problem .... so maybe this could be whats wrong with yours.
S14Juggalo
Car: 95 240sx (S14)
Ima Try that cheap hopefully effective theory thank you good sir!!!
jlb8434
Car: 1995 240SX SE
IT works now.... I took off the door panel and played around with the AMP wire connector while i moved the switch with the car on and BAMM the window moved. I ziped tied the connector of ther amp to the amp. Very happy now. Thanks for the help
S14Juggalo
Car: 95 240sx (S14)
jlb8434 wrote:IT works now.... I took off the door panel and played around with the AMP wire connector while i moved the switch with the car on and BAMM the window moved. I ziped tied the connector of ther amp to the amp. Very happy now. Thanks for the help
Hell yeah Thats awesome! I tried that and it didnt work SOO I tok my amp apart and its Burnt something frosty so i know that the nissan tech wasnt lying to me!
jlb8434
Car: 1995 240SX SE
LOL, sorry for your AMP lose but atleast now you know what the problem is.
S14Juggalo
Car: 95 240sx (S14)
jlb8434 wrote:LOL, sorry for your AMP lose but atleast now you know what the problem is.
Exactly but its all good i bought one off a kat in south carolina and its in the mail as we speak so cant wait to get it in there and figure out how to put the window assembly back together the 17 year old kid i got it from decided to take it ALL apart its a hot mess!
mmaxeyjr
Car: 1995 s14
keep us updated. i havn't tried the ziptie thing but i used a multimeter to test the amperage etc etc.. and i'm not getting power to or from the motor or amp so i have no idea.... it's a pain. maybe the motor but i've read that 99.9999% of the time it's the amp.
S14Juggalo
Car: 95 240sx (S14)
hold on ima try something out for you to see something
jlb8434
Car: 1995 240SX SE
mmaxeyjr wrote:keep us updated. i havn't tried the ziptie thing but i used a multimeter to test the amperage etc etc.. and i'm not getting power to or from the motor or amp so i have no idea.... it's a pain. maybe the motor but i've read that 99.9999% of the time it's the amp.
Good Luck to you, I know your pain... I got really lucky with mine. Hopefully you will too.
S14Juggalo
Car: 95 240sx (S14)
ok nevermind im retarded. Ummmmm try finding the main power wire for the window in your door and if your not getting power there then you might have a short, cut or it disconnected. The right thing to do it track down and repair (solder) But i would just run a wire from your positive and splice it to the main power wire going to the door. I hope this works for you its a pain in the a** i know. Im tired of looking at the black trash bag in my window!
mmaxeyjr
Car: 1995 s14
it cant be cut or a short because it worked fine up until randomly one day it decided it wasn't going to go back up...
240SX97
Car: 1997 Nissan 240SX S14
I'm wondering if anyone can help me here. i recently got a '97 240SX from my uncle and i've been tinkering around with it. i just put in a new audio system and afterwards, it would appear, that my passenger side door window doesn't work anymore. the driver door window still works, but the buttons have no response to the passenger window. i'm not sure if it's the motor, or the amp, or what, but, when i push the window buttons, i don't hear a click, like you guys, i don't hear anything. i put a multimeter to it, and the actuators are still receiving power, and the window fuse is still good, but i'm at a loss. could it be my motor, or my amp???
can anyone give me any tips???
S14Juggalo
Car: 95 240sx (S14)
mmaxeyjr wrote:it cant be cut or a short because it worked fine up until randomly one day it decided it wasn't going to go back up...
Its gotta be if you say your not getting any power to the door check to see if a plug came out or something.
S14Juggalo
Car: 95 240sx (S14)
240SX97 wrote:I'm wondering if anyone can help me here. i recently got a '97 240SX from my uncle and i've been tinkering around with it. i just put in a new audio system and afterwards, it would appear, that my passenger side door window doesn't work anymore. the driver door window still works, but the buttons have no response to the passenger window. i'm not sure if it's the motor, or the amp, or what, but, when i push the window buttons, i don't hear a click, like you guys, i don't hear anything. i put a multimeter to it, and the actuators are still receiving power, and the window fuse is still good, but i'm at a loss. could it be my motor, or my amp???
Take the amp apart and see if theres a burnt part on the board or a solder joint came unsoldered.
This link has been very helpful!!!http://www.nicoclub.com/articles.php?id=245266
If everything looks good id say you shorted out your motor somehow
romero87
Car: s13, s14
if your pressing the window switch and you're not getting power to the regulator or to the amp block then your switch is bad. .......
1996N1ss@n240SX
Car: 1996 Nissan 240SX, 2001 Honda Accord Fully Stacked
i am about to buy a 1996 nissan 240sx the only thing wrong with it is that the driver side window is down....engine is a beaut. new black on black paint...and its auto so even before i buy the car i am having to buy a new window motor
mmaxeyjr
Car: 1995 s14
supposedly a s13 window motor will work in a s14. the difference is the amp but the motor is supposedly the same. I will be trying this out soon.
