S14 wheel offset question
compression
Yes, I searched....
I am looking at getting some 18x7.5 wheels for my S14, and I am wondering about offset. THey are available in +35mm or +45mm offset and I wondering which one to get.THe tires would probably be like a 215-35 or so.I am looking to get the wheel out towards the fender surface for a flush look.Any feedback? thanks in advance.
AJ1356
18x7.5?????? why oh why??loldude on a s14 you can go about 18x8.5 up from and 18x9 or 10 in the rear. i don't know why you'd want to go 7.5 it is not that wide of a wheel and only 215 tires. my old s14 had 225s on stockers. the offset and everythingwould all depend on how wide the tire is and how much lip you want. i'd say maybe go with 18x 8 up front and 18x9 in the rear. i'll find what offset would be good for those sizes if you want.
AJ1356
18x7.5?????? why oh why??loldude on a s14 you can go about 18x8.5 up from and 18x9 or 10 in the rear. i don't know why you'd want to go 7.5 it is not that wide of a wheel and only 215 tires. my old s14 had 225s on stockers. the offset and everythingwould all depend on how wide the wheel is and how much lip you want. i'd say maybe go with 18x 8 up front and 18x9 in the rear. i'll find what offset would be good for those sizes if you want.
chmercer
arent going to be able to pull a flush look with that size wheel. if you simply must get that exact wheel, get the absolute lowest offset that is available.
