S14 VSS, searching brings up contradicting info
skidsteak
I'm in the process of trying to figure out how to wire my KA 5spd into my Lexus. I have done some searching, and I can't find a conclusive answer, hoping you guys can clear this up for me so I can have a functioning speedo.
Is the signal from the VSS Digital, or Analog?
What is the pulse frequency for the S14 VSS?
Greatly appreciate the help, thanks a bunch! :)
SABLT194
Car: 1966 Roadster
The VSS output is definately analog and is wired to the Combination Meter. The Combination Meter Converts to a square wave pulse and sends that signal to the ECU. I am also trying to find out the PPM output for an S14 manual transmission. We're you able to find anythig yet?
Regards,
Steve
