placham »
https://forums.nicoclub.com/placham-u38577.html
Mon Oct 20, 2008 4:46 am
Does anyone have pictures of S14 VSS (vehicle speed sensor), SR20DET(DE) and KA24DE supposed to be the same. This is for manual (5speed) trans.
I changed my gauge cluster on my S13 to 180sx Type-X, my speed is off. To correct this I need a VSS from S14.
I have never seen a VSS from S14, since they are preatty rare.
I got a new VSS from Autozone, but I'm not sure if its the right one. S13 is all metal with long piece of wire and conector at the end.
The one I got for S14 is just plastic with no wire, just a conector plug hole.
Also the shaft where the gear would go on, comes out from the sensor, I'm not sure if this is normal or not. Otherwise I would have to go back and return it.Here are some pictures of Autozone S14 VSS I got, I'm still missing the gear that goes at the end.
If some one has some pictures, please help me out. Thanks.
