placham »
https://forums.nicoclub.com/placham-u38577.html
Sat Jun 27, 2009 7:58 pm
J30 think 95+ is a direct swap "Viscous Limited Slip Differential" back covers are the same between J30 and S14, N/A Z32 not sure think its more like 5 bolt flange which would not be a direct swap with out axles.
All J30's are VLSD, but earlier ones are 5 bolt axle flange, if you want direct drop in head for the later ones.
And drive shaft flanges are all interchangeable between all cars and all diffs.
The only thing that I'm not sure is the ABS, some very between location of sensors, some are on front of pinion and some on ether side of axle out put flanges. That would be the only thing you would have to watch for I think.
That Silver S14a is your car son, in your aviator? Nice looking kouki like color too, I like very much
