S14 VH41DE power steering
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
DRTY14
Car: 1996 FL Ks S14 --- VH41DE manual [DRTY 14]
1988 FL A31 --- SR20DET VCT manual [U DRIPN]
1999 Y34 G ultima --- VQ30DET auto [GLRIUS]
1990 Y31 G --- VG30DE manual
hi guys
im new to the nico club
and what a club ae ! :naughty:
im harf way through my VH41DE convesion
with GTR gearbox into my 96 S14 . was
wondering if any one in new zealand could
help me with a custom power steering pump
bracket / hi presure line ???. i know of the
mazworx kits and havent ruled it out yet
just seeing what i can find a bit closer to
home :dblthumb:
thanks
holeset
Car: r32 skyline
i used an electric power steer pump from MR2 and just made up the lines with braided hoses and fittings or go see someone at Parker Enzed or Hydraulink,i make alot of stuff at work (using lathes and mills all day long) post a little drawing and i can prob wip something up , i know how grumpy old engineers can be and expensive!Im up in Auckland.
DRTY14
holeset wrote:i used an electric power steer pump from MR2 and just made up the lines with braided hoses and fittings or go see someone at Parker Enzed or Hydraulink,i make alot of stuff at work (using lathes and mills all day long) post a little drawing and i can prob wip something up , i know how grumpy old engineers can be and expensive!Im up in Auckland.
thanks holeset
was thinking of using a MR2 pump
can u give me a list of things you
used/had to make to use this set
up , also where is your pump
mounted ? thanks for the help
giz a txt ,2deg 1533 697
cheers !
holeset
Car: r32 skyline
no probs ill get some photos and post them up with a few instructions , mounted under front guard,should be same for your s14, just got the pump on a switch and only really use it for driving under 40k, you could go to the trouble of wiring it up to a speed sensor but my motors never last long enough to warrant this, its got computer gremlins that i am working through at the moment.
DRTY14
thanks mate
sounds good !
cheers
Sender
Car: S15 FGY32 VH41DE
Why not use OEM VH41DE pump? Mine does fit in S15 without any problem
DRTY14
Sender wrote:Why not use OEM VH41DE pump? Mine does fit in S15 without any problem
my pump had about 3 hi pressure
lines coming of it with a gaint
surge tank thing that bolted to
the block from one of them ,
guessing because the 4WS .looked
very confusing so pulled it off
thinking of using a MR2 stering
pump at this stage
cheers bud
holeset
Car: r32 skyline
ill get some photos up of power steering soon as,car been parked up for ages and just got it going good so the motovation is back,how you getting on with the conversion?
DRTY14
holeset wrote:ill get some photos up of power steering soon as,car been parked up for ages and just got it going good so the motovation is back,how you getting on with the conversion?
ok thanks , silvia been put on hold for the moment
been working on my cefiro but it 95% done now
[imgImage][/img]
Image[/img]
got my R32 GTR gearbox back few months back , custom
bell housing , and made RWD looks tasty lol
got my hands on a Y34 gloria ultima (vq30det) too
so got like 5 projects on atm what a mish
cheers for the help .
Return to “VH45DE / VK45DE / VK56DE Forum”
