ca18det_boy »
https://forums.nicoclub.com/ca18det-boy-u12172.html
Tue Oct 30, 2012 9:21 pm
I really didn't want to do this and wanted to figure this out by myself, but due to the fact that I'm losing my garage in 2 weeks the situation dictates that I have to bug the guys who know.
So I thought I had everything wired up correctly but I guess I was wrong. I have 12v going to the injectors and coils, I had things wired up to "My S14 wiring headache's" thread, but then I started to notice some things were different with my swap I.E also doing a 5 speed conversion. I got the motor fired up utilizing starting fluid and it would kind of idle from there. I found out I had a pretty nasty vacuum leak so I took off the intake mani and fixed that issue thinking it might have also been a contributing factor in my issue. I checked the IACV to see if I had voltage going to the sensors and found out that I have good voltage there. I still didn't think things were right with the wiring so I did some more thinking and some more homework and came to this conclusion....I didn't think the ECU was getting the proper start signal. I dug back into the wiring and didn't see anything wrong. Since I was also doing a 5 speed swap I started to think about the neutral safety switch. I came to the conclusion that the Q uses a relay where I believe the 14 uses just a switch. I check pins 44 and 43 and traced all the wiring to find out that in fact I wasn't getting a start signal to the ECU. I was kind of thinking that if the start signal wasn't present then the ECU would default to running a fuel map for 195 degrees thus a crank no start situation. From there I was able to get 0v in "on" and 12.5v in "start" on both wires. Tried to fire it up and it puttered a bit, and crank, crank, crank. I'm not looking for a mulligan on this one, I'm just out of ideas and I'm reaching to see if anyone has any ideas of avenues to pursue in this matter.
Chassis is a 96 SE with a 91 VH, also doing a 5 speed swap
