s14 US SPEC OR S14 JAP SPEC
RICERRIFFIC
Alright, I ve searched my brain out and still cant find an answer. I need to know what the difference is between a jap spec s14 rear diff and a us spec s14 rear diff is. If there is any at all. My jap spec rear just blew up in my car. It was i Lsd rear. I want to get another one but dont have a lot of money. Ive also heard that the infinity J30 rears are the same as the s14 rears. or at least will bolt up and are lsd. I need some pointers. Right now i just purchased a s13 open diff rear so the car would be drivable for the time being. if anybody knows the answer it would be greatly appreciated
virus77
Car: 95 S14, 71 240z, 97 e320
both usdm and jdm models were offered with open or VLSD diffs. It doesnt make a difference which continent the parts are from, it's still the same.
J30 diff is a direct bolt on if its a 96-98 j30 diff with 6 bolt output shaft/axles. The 95 and below have a 5 bolt output flange and axles so you need the j30 axles aswell if you get a diff with bolt shafts.
grimple1
Car: 95 240sx Zenki
I believe that some of the Jap. diffs are geared different. I'm using the 4.36 (4.4) Nismo LSD rear diff. from a s14 sylvia.
I don't think the US 240s came with that gearing. Correct me if I'm wrong, somebody.
RICERRIFFIC
Thanks alot guys. The rear thet blew up was a lsd s14 jdm rear. Im looking to replace it with the equivalent. thats why im wondering about the difference in the two. I loved the gearing that that rear had. im putting in a stock s13 open rear now to get the car moving. Thanks again
