s14 turbo timer wiring?
ibekinq
Car: 240
i have a apexi turbo timer (pen size one) and i only found the wiring diagram for the 92 wiring diagram and i followed it but when i turn off the car and the car doesnt stay on is the diagram the same for all 240s or is it diffrent i have a 95 thanks if u can help he out
SpeedRacer1
Car: 1990 240SX, G35
I know that some S14's are different. I recently put a turbo timer into my friends car that had come out of a JDM S14 front clip. It turns out the ignition wiring for the USDM S14 is different than the USDM S13 and JDM S14. I think that if I remember corectly I had to add an extra wire to the turbo harness because the S14 had a wire that the turbo timer harness never came with. However if i remember correctly this wiring difference made his car not turn on properly.
Did you check to make sure you installed the e brake sensor.
s13_drftone
Car: S13 with sr20det swap
check for e-brake wiring? recheck wiring
da40
Car: 1995 SE 240sx
does the e brake wire determine the timer from working correctly?can u use the timer without the e brake option i had a greddy timer and i never had to use the e brake option and it would work thanks guys
bigodom1
Car: 95 240sx swapped and 95 gmc sierra daily
when i tried to wire mine up that came in the clip after using the timer i could not crank the car again i thought it must have been some sort of security but i dont get it
da40
Car: 1995 SE 240sx
i gave up on mine last night used the test light ,volt light all was hooked up right and even hooked up the e brake still when i turned off the car it would shut off not count down
smokey240sx
where did you ground it?
da40
Car: 1995 SE 240sx
grounded it to the chasis, it turns on and all but wont count down after i turn the car off
ILikeMy240sx
Car: SR Power
Its is way easier just to get a harness for it. 14 bucks is only thing you would pay and it makes the job much easier.
As for the e-brake signal line... yes you would need to hook that up otherwise your turbotimer will not work. It's a safety measure... if your car was running on the turbo timer and the e-brake disengages then it will automaticallt shut it off. So, if you do not have that line hooked up the turbo timer will not let the car idle.
da40
Car: 1995 SE 240sx
yeah gonna go with a greddy and the wire harness to bypass time and error
