S14 TRUNK LEAK????
lsxavier
Car: 95 240sx se ka-t
I searched for trunk leak for an S14 and can't find anything. I sealed the tailights and it's still leaking somewhere. I cant' figure it out. If anyone has experienced this, please let me know.Thanks
DrunkDRIVER
Car: 1989 240sx
heres a idea....strip the trim of the trunk down.... lay in the trunk with a flashlight....have a buddy spray water all over the trunk from the outside...and use ur flash light to look around and see where water is comin from...
180fan
Car: 89 fastback
or check behind the tail lights. Those seals can give out too. Additionally if you've a spoiler, you should check where the spoiler meets with the trunk lid.
0wn3r
Car: 1997 Nissan 240sx SE track car (SR20DET, caged)
i wish i could show you a pic of what mine was just doing... but it's dark out and it's in the shop.
take out the spare tire... towards the front/passenger side of where it sat, there's a black circlular plug about 3 inches diameter... well if you push on it, chances are it will just pop out onto the pavement like mine did. i took some of that 3m fender tape and went around it and stuck it back onto the body... haven't noticed a leak yet though.
there's actually two of them, the other black one is a little bit bigger i think and more towards the rear of the spare tire-well but should be sealed a little better than the other.
if that was confusing, let me know and i'll snap a pic lol
lsxavier
I found the leak. My trunk lid needs adjustment, it's sitting up a lil bit so the water goes thru the weather stripping. I adjusted it and it does'ntleak any more.Thanks for all your replies
0wn3r
lsxavier wrote:I found the leak. My trunk lid needs adjustment, it's sitting up a lil bit so the water goes thru the weather stripping. I adjusted it and it does'ntleak any more.Thanks for all your replies
it wasn't noticeably higher than the rear fenders?
