PMan_S13 »
https://forums.nicoclub.com/pman-s13-u3715.html
Sun Mar 06, 2005 3:27 am
you can use a lot of different transmissions on the ka24/sr20 motors.
I would certainly look before I leap on this... but all year 240sx/Silvia transmissions are swapable because they use the same transmission-bolt-on-pattern.
Auto/Manaul/S13/S14(95-96)/S14(97-98)/KA/SR <--- pick any combo you want, it doesn't matter..
BUT BUT BUT, you can't use the same driveshafts between s13s and s14s.. the s14 has a bigger output shaft from the transmission. The length of the driveshaft is different too... but sounds like it is a s14 - s14 swap anyway.. no worries.
I don't know about the s15 or 300zx, but it's easier to find a used s14 transmission anyway.
You probably could use the transmission from a Nissan hardbody truck too, they have the same (well, almost) ka24de motor
Long response, but hopefully helpful
