S14 Transmission help.
DMan II-40
Car: 1995 240SX SE
So I broke that crank angle sensor on top of my transmission (anyone know the part number), that was a pain. My question was about the two bolts on top of the transmission, they were VERY hard to take out, is there a trick to that or anything? What about when I put it back in, what is the best way?
motoman399
Car: 98' wrecked (RHD coming soon) 240
i use a wobble socket andlong extensions for mine..
DMan II-40
Car: 1995 240SX SE
I'll have to try that when I put it back. Anyone know that part number!?!? (bump before work)
Edit: NVM I called them and they found it for me. 23731-S14001 is the part number for the Crank Angle Sensor (CAS) just in case someone else tries searching for it.
motoman399
ill double check that part number for you just in case. ill check back later and let you know.
