s14 trans harness???
heartofaskyline
Car: 1992 hatch, 1993 sr20 coupe
anyone tell me what plugs go to what? all i really need to know is which one is for the speed sensor and which one is for the reverse lights. im trying to wire this lower harness to my s13 and im having problems
heartofaskyline
bump???
diggles240
Car: 1996 240sx SE
2005 Altima 2.5S
So, are you installing an s14 lower trans harness into an s13? For an s14 lower trans harness: speed sensor should be R + R/Y and reverse lights should be G + G/W. The colors will be different for an s13 harness- speed sensor Y/L + Y/B and reverse sensor G/L + G/B. This is in the EL section of the FSM. Good luck
heartofaskyline
sweet! thanks, i dug thru the fsm and all i found was this
do i have to change anything else to use the s14 harness in an s13? ive searched, and it said something about the s14 harness having 2 plugs where the s13 box has 3
diggles240
Car: 1996 240sx SE
2005 Altima 2.5S
heartofaskyline wrote:do i have to change anything else to use the s14 harness in an s13? ive searched, and it said something about the s14 harness having 2 plugs where the s13 box has 3
The s14 trans. has (3) sensors, not including the speed sensor: from front to back of the trans.- reverse (in bellhousing), 5th, then neutral.
The s13 trans. has (4) sensors, not including the speed sensor: from front to back of the trans.- reverse & 4th position switch (both in bellhousing)then 5th and neutral in the trans. casing.
The trans. diagrams are on MT-4 (s13) and MT-5 (s14). I would post pics of the layout from the FSM, but this comp. does not have photoshop and microsoft paint sucks
heartofaskyline
your a lifesaver, thanks bro! i just found the harness layout in the el part of the fsm.
diggles240
Car: 1996 240sx SE
2005 Altima 2.5S
no problem....anytime dood
Kevin
heartofaskyline
tomorrow i get to enjoy converting the lower harness to work with my s13, o joy lol, maybe ill do a write up since i always talk about doing one and never do. lol
diggles240
Car: 1996 240sx SE
2005 Altima 2.5S
heartofaskyline wrote:tomorrow i get to enjoy converting the lower harness to work with my s13, o joy lol, maybe ill do a write up since i always talk about doing one and never do. lol
Or we can swap lower harnesses (or harni). I have multiple s13 harnesses and I need an s14 harness.
heartofaskyline
really? shoot me an email.
[email protected]
diggles240
Car: 1996 240sx SE
2005 Altima 2.5S
ok, in the morning though. i have to wake up for work in a few hours
