s14 transmission to an s13 ka24de engine
joevanni
Car: NIssan 240sx
hi guys ive been wondering if i could use an s14 5speed transmission on a 91 ka24de engine.
ashoe
Car: 1996 nissan 240sx se, 2006 subaru wrx
Trans is the same, you may have to use the s13 bellhousing.
chrismo240sx
Car: 92 240sx HB
S13 Blacktop
i used an s14 transmission on my s13...only thing is you have to cover or ploug a sensor hole on the s14 transmission. The s14 has an extra sensor that the s13 didnt have, forget exactly what plug it was but when thats plugged it works fine.
Just compare the 2 transmission's when u have them next to each other and you will see the hole im talking about!
joevanni
Car: NIssan 240sx
aight ill do that tommorow
joevanni
Car: NIssan 240sx
can u show me a pick of the bell housing not that familiar on transmission's
ashoe
I don't have a pic of the bell housing handy, but its the bell shaped thing that bolts between the engine and transmission. the clutch and flywheel are inside it. Take the bolts off, and give it a little motivation with a rubber mallet. It should come right off.
joevanni
Car: NIssan 240sx
k ill do that thanks guys for ur help
