s14 transmission ???? ta71b # 8...
romero87
Car: s13, s14
Im looking to order a synchro and bearing kit to have my transmission rebuilt. However i can't seem to find out exactly what transmission i have... All i see on the transmission its self is TA71B # 8 and then on the tail shaft section of the transmission i see a #2 and thats it... When i searched for the kit i came down to 2 choices...
240SX 4 cyl 2.4L 1993-97 Aluminum cases, rear load DTS-BK133 $131.98 DTS-BK133CWS $165.98
240SX 4 cyl 2.4L 1993-97 Aluminum cases, rear load - 31 .25mm O.D. large pocket needle bearing DTS-BK133E $140.66 DTS-BK133FWS $271.32. Does anyone know which one i might need? or how i would be able to tell if i have the 31.25 od large pocket needle bearing? Thanks..
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Is say call the company, or a transmission repair shop. When you find out post back here because it seams to be a common question lately.
