turtl631 »
https://forums.nicoclub.com/turtl631-u15171.html
Mon Oct 03, 2005 5:35 pm
I'd like to get an S14 when I get back in the country and set it up for track days. Based on reading a ton, owning another s14, and some correspondence with others who have tracked s14s, I think I've got a basic idea of what I want to start with. Wheels/tires will likely be 17x8 and 17x9 with 235/45 and 255/40 Kumho MXs (chosen for low cost, heat tolerance, and learning...don't need R comps to begin). From what others have said, running no stagger results in a really tail happy car at high speed, even after adjusting other components. For suspension stuff, I'd like to get some softer coilovers...maybe KTS with 7/5 rates (kuah said they'll ship them with +/- 1, but not revalve...based on how most jdm coilovers are underdamped and how that's not ahuge change in rates, i think that shoudl be okay). I really don't want an overly stiff car, and 8/6 is higher than I'd like. Its hard to find cheaper coilovers that aren't 8/6 or higher. To start out I'd also like some SPL tension rods and subframe spacers...the other arms can wait (I'll just not lower the car much to avoid running out of adjustment). If I want to tweak out some roll and adjust balance, I'll probably get some progress sways. Any parts of the setup sound totally off base? The coilover thing really gets me..I'd love some 6/5 or 5/4 coilovers of KTS quality/cost. 8/6 shoudl be okay for smooth tracks, but I really feel that's just overkill, especially on street tires. I also don't want to run like...AGX with springs. Not having height or front camber adjustment would be kind of annoying, and I'm not too confident in the damping on the AGX. Any suggestions?
