S14 top end help
ca18det_boy
Does anyone happen to know where I can get the bolt that holds the intake cam gear on?
Hijacker
Car: '92 240sx Convertible
'94 F-150
do you still have the old bolt? if so, I would take it to a shop that specializes in bolts and fasteners and have them size up a new one for you.
If you don't have the old bolt, you may be SOL. I'm not certain on this, but 300ZXs came with VVT in their later years, and knowing Nissan, they may have used the same cam bolt.
ca18det_boy
bart yet again you come to the rescue. I don't have the old bolt but I know the pitch. The sad part is that it has to be like a stud or something because the new bolt threads into the cam just fine but won't go through the VVT solenoid. I'll have to check on the z32 thing but at least its another place to look into.
