sil8tdrifter wrote:I just bought a '93 s13 240sx from California, with a blown A/T. Structure240sx is willing to sell me a A/T from a '95 s14 240sx.#1) Will it bolt up to existing mounts and my Eng?
Yes
2)Will my s13 Tran. harness/sensors plug into the s14 Tran?
My understanding is yes to the harness, but the sensors may be different. You'll know when you try to start the carSomeone else should be able to answer with more certainty. I just know the sensors for MTs can vary between S13 and S14.
3)Can my driveshaft bolt to the s14 tran?
Yes. Trannys are more or less the same (minor changes) though the driveshafts differ. May require some dustcover "modification" but should fit. 4)Is the gearing different, taller/shorter?This, I don't know for sure, but I'd imagine they are the same.
Someone Please Help!:bowdown
