s14 to 2b20 ps pump+ custom high pressure lines.
PorkChopExpress
Car: rb kouki
fist off i read that the s14 hi pressure line will just bolt up to the rb20 ps pump.not true for me, the banjo bolt will not fit through the s14 hp line.
second, reading about the custom earls hp line. some people have leaking issues with this setup? something about the an fittings bottoming out and not sealing? someone else have experience with that? can i just double up on some copper washers?
oh and third, where do you guys get that awesome little ps cooler?
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I haven't run the system yet so I can't comment on the fittings leaking, but I got the little PS cooler from summitracing.com. Look up Perma-cool. It is like $25 and it comes with fittings, clamps, and line too.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
I've only ran into the custom earl's line leaking once on the pump side and just changed out with a thicker copper washer, bingo.
