driftingmy240sx »
https://forums.nicoclub.com/driftingmy240sx-u80467.html
Thu Feb 28, 2008 2:08 pm
are you using the ka24 sender? the sender works by a resistance value determined by the temp. at cold temps there is a high resistance value, when hot a lower resistance value. if the gauge is good and the sender is good you have some sort of outside high resistance n the wire from the sender to gauge. you can used a volt meter on the ohm setting to test the wire and if it good should have less that 1 om resisatnce.
to test the wire the sender and gauge must both be disconnected. to see if the gauge is working before testing the wiring disconnect the sender and groung the wire with the key in the on position. the gauge should read full hot. if it does not the gauge is bad or you have a reistance problem in the wiring. if it does peg full hot when grounded the sender is bad.
make sure you are testing the single wire temp sensor not the 2 wire sensor (1 wire is for gauge, 2 wire is for ecm)
