s14 tach help please
lowredcruzr
i have a 96 240sx se 5spd, and the other day i was driving and noticed that the tach would no longer go over 3800 rpm. the next day it wouldn't go over 2600rpm any idea what might be wrong or how i might fix it, thanks for the [email protected]
s13sr20chris
that sounds like a busted tach. the motor does rev high right? if the motor revs and the tach does not register it, you have a bad tach. this is because the ecm must see the signal to keep the engine running.
lowredcruzr
yeah the car still revs fine just the tach wont work properly. i'm guessing i should just replace the cluster
NISTECH
you can replace just the tach inside the cluster. Nissan sells it seperatly.
lowredcruzr
thanks for the reply i'll look into that
