s14 swap in s13 ???
silviaS13lover
Car: yellow llama onevia
ok b4 you flame, i have done research on this but im not sure if i understand it all so im trying to clear it up. first off a friend just did an sr20 in his s14 so his dohc is just chillen at the shop. he said i it has engine/transmission,dizzy, intake, engine harness. everything takin out of the s14. so i have a 91 s13, but it has a ka24e. the guy bfore swaped it. anywho. what needs to be done to make this all work in my s13. ps lines and the harness needs changed. a little help on this to clear it up would help. or a good down to earth link. thanks very much. happy 240ing
Philsnotfalling
Car: 90 hatch 93 coupe
have the harness cut and spliced to work in your s13. I had mckinney do mine. And yes the p/s lines need to be moved from one side of the engine bay to the other. Everything else should bolt in. don't forget the ground sstraps from the head to the fire wall.
silviaS13lover
dope. thanks alot..
