s14 swap in a 91
2ueceka24de
Car: 89 240sx 93 ka24de
i just recently swapped my s14 ka into ma 91 body nd i have a plug for the lower wiring harness for the transmission that goes completly no where??? can ne1 help me here do i need to get a s14 lower harness or is my transmission missing that switch i will post pics lata b/c i do have other problems but with out pics wat good is this thread......also when i start the car my acc relay goes off i was guessin that switch but i have 3 more switches that im kinda lost on so i will post pics asap thank you 4 the input
ShouldaHadaV8
Car: 92 hatchback 240sx, j30 diff, TIEN tie-rods
more info!
are you using the s14 wiring, engine, and manifolds, or the s14 engine with 91 wiring , 91 intake and exhaust manifold, and 91 distributor? hopefully you made it easy by using the 91's wiring. because if your using the s14 engine harnesses i belive that the mystery transmission harness is for a crank sensor on the s14 transmission but IDK.
2ueceka24de
i bought da engine from sum kid he said that the wiring was made to work with an s13 so im preety sure its s14 wiring(plus the connector under da dash that runs off the ecu wouldnt fit so i wired it off ma s13 harness to fit) but ma lower harness is from the 91
2ueceka24de
this is sum random wire dont know where it goes or if it is even important but it is part of the 91 lower harness nd is right next to the fuse box nd tb and yes my alternator is hooked up
this behind the intake inside near the brake booster this is part of the harness attached to the motor wen i bought it dis was like this ne thoughts on this??(yes is s14 harness)
now this is the plug for the transmission that jus sits there that is a s14 transmission nd a 91 lower harness
a closer look at the exact plug
and wat it pluged into off ma s13 transmission
this is wat i rewired that was in the dash preety sure its for accesories this plug(white) wuld not fit so i wired them my self now the wires cut off to the side was like this already dont know y but guessin it was s14 s%*# so i only rewired wat they originaly had wired so do i need these or not?? this is the reason y i assume it is an s14 top wiring harness plus its wat the original owner stated but pls correct me if i am wrong(wires that are connected blk,orange,yellow and red, and yellow and green, and blue)Image
Ne information is much appreciated nd thank u nico club :mike
benz88
Car: 91 240sx
here, you leave the one unlpugged, I just did this in the summer
Leave #3 unpluged
2ueceka24de
tahnks man much appreciated now if i can get my acc relay to stfu :biggrin:
benz88
Car: 91 240sx
s*** follow those pics, plug all 3 in but you'll have the 2nd shortest cable from the front unpluged. leave it like that.
2ueceka24de
car cranks now but wont start it sounds like my starter is working really hard or ma battery is dying from trying to crank it so much :gapteeth: so im going to put in the right ecu soon and i hope it starts up
