S14 Suspension noise!!??
Tayluh_240
Car: 1995 Nissan 240sx s14
This problem has just recently occurred, coming from the front when I turn the wheel left or right, It makes a loud noise. As if there is a dry rubber bushing rubbing something. (thats what it sounds like)
When it rains though and I drive in it enough for the underside to get wet, it goes away. So I guess its a dry bushing. But does this mean I need to replace the front lower control arms or the front tie rods??
Tayluh_240
Also, when the front of the car is jacked up with no pressure, the noise goes away when turning the wheel,
poshatch
Car: p.o.s. 1990 240sx hatch
i really couldnt tell you what it was but i would suggest jacking it up and taking off the wheel checking every arm, bushing and ball joint to be sure they dont have play and what not..give them a yank or move them in some way to see if you can pinpoint the problem
Hdub253
Car: 1996 Nissan 240sx
I'm not quite sure if the noise you are hearing sounds like the problem I had, but you could be getting low on power steering fluid. Check where you park for a small puddle of the stuff, if so just refill the power steering fluid.
