s14 supsension swap
s13.4VERT
Car: 93 240 sx vert
I'm new to this platform and I have a quick question concerning an s14 suspension swap. Would an SE 5 lug suspension swap bolt right into an s13 vert? Meaning the whole suspension not just then hubs? Just looking for an easier route.
95silvia14
Car: 1995 240SX, 1993 s13 coupe
The front will go on with out a hitch usally. but the rear is another story if your talking about putting in the s14 subframe then you can molest the stock bushings to make it fit but you will still have some slop but yanack racing has a off set solid bushing you can buy but there 250. last time i checked. it would be cheaper taking the bushings out of the s14 and fabing a dounut to weld to the subframe in the offset possition. but you would have to be extra carefull of keeping all the geomerty in line and not having it sit in the rear cockeyed. easily put dont worry about the subframe but if your gun ho theres a start for you
