sdtouge »
https://forums.nicoclub.com/sdtouge-u17787.html
Sat Aug 20, 2005 8:50 am
if you want i have some collars than you can have for like 10$ shiped lol.
but i would recoemdn not the spl ones for gnarlieness of install, but i recomend a metal slotted one, i just did mine yesterday took 15 min. the tops ones are slotted so you dont need to drop the subframe.
just remove the 4 subframe bolts, 17mm i think, but first jet a jack and jack up to the diff , then when the bolts are out lower the subframe till there is enough room to pop the ones up top. the flat side goes up, then on the bottom youll figure it out. then i acually had another jack (do the front ones first) and jacked up the subframe the press the bushings in really good, then tighten.
you ca et them off ebay from techno toy tuningn (i got mine fro them, like 54$ and they are great quality fast shipping)
good luck hit me up on aim if you have any question
