PabloHoney »
https://forums.nicoclub.com/pablohoney-u320.html
Tue Aug 13, 2002 9:59 pm
Well, I was tired of having to choose between having good sound, or sacrificing trunk space and/or not being able to corner hard without the box moving. So, I got my Construction Engineer brother to help me out with a sub-box.
The design is for two seperate boxes, sealed, for 12" speakers @ ~ 0.8 cu. ft. of air space (can be changed very easily). They are placed on either side of the trunk, and partially use the fender for air space. This means you have to move the carpet aside that is there, or take the side sections out ( what I am doing). This also means that you have to remove the jack and the metal piece that hold the jack in. Anyway, you can figure out the rest by looking at the AutoCAD drawing that is linked below. It was done in AutoCAD 2000, but I can get it saved in R14 or whatever if someone wants. I will also export it to a JPG for those of you who don't have AutoCAD.
AutoCAD Drawing.
