gtd65 wrote:Do you need to put much force on the long bolt through the bushing to get it released?
I was thinking about picking up a cheap torque wrench or breaker bar to give more leverage if necessary?
You mean the bolt that holds the T/C rod to the car or the steel sleeve the bolt goes through in the bushing? I've had the bolts seize in the bushing and it's kind of a pain to get it out of the car. I pushed the sleeve part out with the majority of the rubber in the bushing with the press, It ripped out pretty easy, but I'm sure there was some force on it. If it is the bolt that's suck, penetrating oil, time, and vibration are the keys to getting it out.
I bet if you wedged the bushing under something a 2 ton bottle jack could push the center parts right out.
That bushing set on ebay you linked to looks pretty identical to what I put in. I'm sure there are better ones out there, but that's what I used.
