s14 starting to smell like gas from engine bay
DisFrikkenWill
I never had this before but recently my '95 S14 has started to smell like gasoline after driving it. I can even smell it when im in the car with the a/c on, its like seeping in. I dont see any leaks anywhere in the engine bay or even looking under I dont see any leaks dropping to the floor.
Any ideas/tips? I just wanna see what may be the cause and try to fix it before it turns out to be problem.
Thanks
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
It's probably your carbon canister if you have one. All it does is vent the fumes from gas tank to your intake.
