S14 Stalls when clutch pedal is depressed while idling
andrewdees
Car: 97 Emerald Green SE
I finished my 5 speed swap today. I put in a lightweight flywheel and a new clutch. The car drives and shifts fine. When idling and I press the clutch pedal down the car bogs down and sometimes stalls out. It also makes a squeaking noise when the clutch pedal is pushed down. If I give it some gas then press the clutch and shift into first it works good. I'm confused. Any ideas????
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Your throw out bearing is binding. Did the Clutch kit come with one? Could be bad throw out bearing or pivot ball.
andrewdees
Yeah I put on a new throwout bearing and pilot bearing.
