S14 sr20det with a/c
jamanrr
I have a problem that has gotten a little worse. I need to know how to hook my fast idle control for the a/c back up. I was running my car with the a/c in hot weather and my idle will drop the only problem with this is the oil pressure also drops. It scored up the number one cam lobe pretty good. I turned the a/c off and the idle and oil pressure came back up. I know most people with sr20 swaps do not run air conditioning but it gets hot as hell where I live and I would like to keep it. I run an apexi a/c so is there a way in the pfc to increase the idle with the air conditioning running instead of having it drop?
