Hoffman5982 »
https://forums.nicoclub.com/hoffman5982-u77367.html
Wed Nov 17, 2010 10:21 am
not the whole harness. You'll need a couple of plugs, but thats it. If you have a junkyard around you then you could easily find the plug you need from anothr nissan. I had to use the siper amp plug(mine was cut off on the sr harness, Idk if youll need it) and I used a couple of plugs from the ka harness to replace the sr ones because they were broken.
So in short, no. You just might need a few plugs
