dubvdrifter wrote:Yea I figured I'd get flamed that's why I posted it here instead of zilvia forms. I have also looked into a ls swap Just not my style of swap. I'm a boost junkie
lol what's your input on a rb25 I've here there not reliable because of the oiling issues but some have found ways around it.
The RB oiling issue is actually blown way out of proportion. The issue is that the lands on the crank for the oil drive gear are usually too short, and at overly high or sustained high rpm, it tends to make the ring fail due to vibrations and not enough contact with the drive surface. On a stock RB, revved to stock rpm, odds are you'll never have that happen. The "more power" solution is to have the crank machined to allow a crank collar (usually like $150 for the collar) to be pressed on - fixes the lands-too-short problem. For "more power" AND "rev past stock redline", you'd do the crank collar, and use a stronger oil pump, and get a better harmonic balancer. One thing about the JZ is that, to my understanding, to get to 500HP, you'd have to get rid of the twins and go single turbo, and some custom fab exhaust work is needed cos the exhaust is on the ther side of the engine / car. It really comes down to preference in the end, even if it's "what would I rather hastle with".
I'm with ya on the boost over displacement. V8's get low milage no matter what. Boosted compacts only really guzzle fuel under boost. I have an RB25, and I know a guy with a 1J in his lexus - both are very streetable and road-trip-able when you dial the boost down, then just crank the boost up when you want fun. RB25 stuff isn't all that expensive if you know where to look. New for new, JZ stuff is more expensive than RB stuff alot of the time. Either one would be awesome.
I agree that if your goal is 500hp, you probably don't want an SR or a KA-T. RB25 or 1JZ would chew that up and spit it out like nothing. 2J's are amazing, but the price goes WAY up for a motorset compared to 1J or RB25, especially if you want the 6 speed transmission.
So yeah. RB25 or 1JZ is what I'd suggest.
