wafflez66 »
https://forums.nicoclub.com/wafflez66-u19144.html
Wed May 03, 2006 4:50 am
I finished putting in my S14 sr20det into my 95 s14, and I added a fmic, exhaust, 255lph fuel pump, and bov. I had a few problems getting it running, but it runs great now under low throttle, but under hight throttle it dies right out, and back fires like crazy. I have an safc II wired in b/c I originally had a z32 maf installed, but found out it was shot so put the stock one back on. To add to the problem, it'll boost great and pull hard when you first start it up and run it, and from time to time. It boosts to 7 psi constantly ( I don't have the boost silinoide hooked up), but it's like it isn't getting enough fuel, or too much b/c it's like it isn't using the boost. I'm not familiar w/ how to use an safc, and tried tuning to spec, but reset it b/c it only made things worse. If I unhook the safc it runs terrible. the in and out are set to 0 0 in the hot wire sensor. any help would be great.
Jonathan Van Ness
