S14 Sr20det PS interchangibility
NEED4BOOST
Well does anyone know if the s14 sr20det power steering pump & the bracket is interchangeable with any other nissan motor?
Also does anyone have one for sale?
Thanks,
Safa
NEED4BOOST
hmm....I guess no one knows
lok
I used the ps lines from a s14 in my s13 sr20 swap. I didn't have to modify any of the lines nor the high pressure lines. I am not sure about the pump but like I said I didn't have to modify anything.
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
I dont know about the SOHC, but the DOHC KA motors have the same pump as SRs (just dif bracket mounting). Same goes for S13 SRs. Basically a DOHC KA, S13, or S14 PS pump will work for sure (I know because I have all three pumps).
Cyberkreig
Car: 1993 Nissan 240SX SR
I thought that the pullys were different between KA & SR pumps?
I wonder if a fwd sr ps pump would work.
NEED4BOOST
ItzGenX wrote:I dont know about the SOHC, but the DOHC KA motors have the same pump as SRs (just dif bracket mounting). Same goes for S13 SRs. Basically a DOHC KA, S13, or S14 PS pump will work for sure (I know because I have all three pumps).
Do you have any of the brackets for the S14 SR for sale? I have a KA PS pump.
ItzGenX
No, I do not have any brackets for sale. My main bracket was still bolted to the motor when I got it, but my intermediate bracket that holds onto the pump itself was not there, so I bought an sr pump with intermediate bracket on it from ebay. I've seen whole power steering units including brackets sold on ebay. I have yet to know if the brackets are interchangeable though.
As for the above, yes the KA has a different sized pulley (its bigger), but the pump is overall th esame. All you do is switch it over to the sr bracket and change pulleys (greddy, project silvia, etc).
martin
NEED4BOOST wrote:Do you have any of the brackets for the S14 SR for sale? I have a KA PS pump.
I have a S13 SR PS pump and brackets. I believe its the same as S14 , shoot me an offer if you're interested.
-Martin.
Cyberkreig
Hey martin, way to read my sig. You dont have email in your profile. hit me up at [email protected]
USsil80
i just got my sr20 and the power streering pump only has one line..but on my ka pump it had twolines comming out of it....soo i should just use my ka pump right..lilttle heads up i have a 92 hatchback with hicas(is that the reason for two powersearing lines)thanks
GhostRider240sx
Car: 2008 G35x Sedan
Journey
StocK
Tried using a ka, but it won't fit on the sr bracket :(. I have a 91 240sx and did the sr swap. the Sr PS pump is busted. So any idea on how i can mount the ka pump?????
