fast_s13 wrote:as long as you have the factory boost sensor hooked up it will run 12 psi
Oh man this rumor again. 7psi is the factory boost level, even with a properly working boost solenoid. However, if you replace one of the lines on the boost solenoid that contains a restrictor then it'll bump your boost up. The Aussies do this all the time as sort of a cheap boost increase.
Most people don't get a boost solenoid included with their motorset and most others that do replace the lines with their own, which of course makes your peak boost higher. I actually tried this on my S13 blacktop prior to my AVCR. I was getting 7~8psi with factory boost solenoid lines, once removed it was bumped up to 10~11psi.
