s14 SR20DET issues
kouki850
I just installed an SR in my 97 kouki, the car pulls strong but when I keep the throttle at the certain point, it shakes like misfire, and idles high.bored out to 2.1 JUN pistons. HKS metal head gasket, z32 maf with safc. any helps?
Modified by kouki850 at 5:20 PM 3/24/2009
fast_s13
what kinda bov you running
kouki850
I don't have 1. today I changed O2 and changed spark plugs with NGK BKR6 .30 gap. got ignitor chip and CAS from my friend and problem still occur
fast_s13
you migt want to get a bov also check timing.. so your bored out to a 2.1 whaat sleeves ar you running
kouki850
I don't really know. I just changed coolant tem. sensor and adjust the CAS while the engine was running but no help
