badass240sx »
https://forums.nicoclub.com/badass240sx-u2748.html
Wed Jul 23, 2003 5:29 pm
Hey guys, need some help here. I have no idea what the hell is going on and it's pissing me off, lol. Anyway, the car is 91' coupe w/ an S14 SR20DET swapped in. Had it for about 2-3 months now and everything has been doing very well, ran great. Suddenly my car has started to bogg down and almost die while coming off the gas and pushing the clutch in when coming to a stop. Then while im at the stop it'll idle very rough, bouncing from 400-1100rpm. It's not consistant though, sometimes it'll idle just fine and others it wont. Yesterday all of my electronics/power cut out while bogging out like described then immediately come right back on and the engine came back to normal. Also, when im making a run after 6k rpm you can feel it bog down slightly, it's very weird. Even when im at a complete stop and park while going from 1st to reverse it'll bog down and almost die. It's like someone is disconnecting my ground terminal from my battery then immediately putting it right back on it or something, odd to describe.
In attempts to solve the problem I have been monitoring my turbo timer and APEXi S-AFC to keep an eye on the battery voltage, it seems to be fine; when first started it holds at 12-12.3V then drop slightly after time. But it never goes below 11.3-11.4 so I don't think it's my battery, I have alot of electronics so im sure it's just actually using the juice. I then found my battery ground had been loose, you could literally pull it off. So I got some new terminals and replaced both the power and ground on the battery, very tight connections on both now. I'm running out of ideas here guys and have no clue what the hell is causing my problem. ANY light you can shed on the issue would be most appreciated.
