ArcherV20 »
https://forums.nicoclub.com/archerv20-u10126.html
Mon Apr 23, 2007 10:53 pm
I'm preparing to do this very soon, so hopefully I'll have a write-up on it. Anyway, these are the steps essentially:
1: Mount the A/C compressor, and condensor from the SR engine. Which should be fairly easy.
2: You will need the A/C lines from the SR and the KA. I forgot which goes where, but if you start putting things together you should figure it out, but the ends of the SR (or the KA) lines need to be cut off, and welded onto the other set of lines. Don't quote me on this, but I believe the KA line needs to have the SR connector welded on, then have it run to the compressor then from there you'd need the other KA line with an SR connector on it, run from the A/C system back to the car.
3: Go to a rad shop and get your system charged.
Theres a few wires to connect, but that should be the easy part. I'll try and make a decent walkthrough.
