s14 sr20det into s14
smithers584
ok i have searched and searched, can anyone tell me what wires to swap at the f3 connector, and which ones are not needed? or at least give me a site to go to, i have swapped everything per the pinouts on both harness's. just want to get someone to verify before we install other crap. thanks
xero1
Car: 08 Altima Coupe
so all the other connectors on the us s14 are the same as the jdm s14 except for the f3 connector? i searched and couldn't find any instruction. let me know what you find.
highmilehatch
Do you have both the S14 KA and S14 SR FSM's? If so, that is all you need to figure it all out.
streetspirit7
Car: '97 240sx
I attempted to do this as well, after about a month of searching and still not knowing what exactly to do I broke down and sent it to Yuri at Wiring Specialties. He did an excelent job on my wiring harness.
smithers584
ok well i got it done and it was very simple. serisously, if i had to do another one it would take me about 15 minutes.
xero1
so only the f3 connector needs to be modify for the s14 sr20det swap.
highmilehatch
Yes. And you will need to rearrange some pins on the wiper motor plug.
xero1
did you drive the car after swap, can you feel the vvt when it kicks in?
Lantz
Car: '96 240sx KA-T (kouki conversion)
does your a/c work with your wiring? it seems like that never works in swaps
highmilehatch
My A/C and customer's cars A/C work perfectly as it should from the factory. All you need to do is wire it up correctly.
