AJ1356 »
https://forums.nicoclub.com/aj1356-u13627.html
Tue Sep 19, 2006 2:35 pm
Here, you might find this information usefull
Engine Harness & Electrical Connections
Back to Top
Our engines come with a complete, uncut harness and lower engine harness that includes the transmission sensor plugs and the starter, alternator and oil pressure sender wiring. Common places to have the harness incorrectly cut are where it runs into the firewall to the ECU, and right at the back of the valve cover, keeping the injector and plug harness, but usually missing the ECU, MAFS, igniter chip and their wires. There are 2 plugs on the end of the KA harness and 3 plugs on the SR harness that run up behind the stock battery location. Although the plugs do initially snap together, the wires do not line up and you have to cut the plugs off and connect the wires using the table below. Cut the 2 main KA plugs off the KA harness and splice them onto the SR harness.
SR Harness Wire Color Use KA Harness Wire Color Black / Pink stripe Fuel Pump Relay Black / Pink stripe Green / Orange stripe Transmission Neutral Sensor Green / Orange stripe Red / Black stripe ECU Relay Red / Black stripe Green / Yellow stripe AC Relay Green / Yellow stripe Red ECU Backup Power Red Black / Red & Blue / Red (Note: connect 2 wires to 1) Main Ignition Power Black / Red stripe Black / White stripe ECU Power Black / White stripe Blue / Green stripe AC Relay Blue / Green stripe Black / Yellow stripe Idle Air Control Valve Power Black / Yellow stripe Brown (to O2 sensor) O2 Sensor Power Any 12v switched source
The MAFS and power steering sensor wires need to make it over to the front driver's side of the engine compartment, use the MAFS and PS wires from the KA harness to extend these wires. The AC compressor wire from the KA engine bay harness should be used NOT the SR harness AC wire (even though it fits). The starter and alternator plugs to the fuse box are all the same and plug right in. There are several unused and leftover harness plugs, anything not mentioned here does not need to be connected.
ECU & Dash wiring
The colors on the wires that run from the ECU up into the dash matched up perfectly on both the SR ECU harness and the KA dash harness:
Back to Top
Wire Color Use Yellow / Red stripe Tachometer signal Yellow / Green stripe Speedometer signal Orange Ignition start Black (may be more than one ground) Ground Blue / Green stripe AC signal Blue / Black stripe Water temp signal
The rest of the wires are for the CONSULT diagnostic device. It is not necessary to connect any other wires than those listed above to get the SR to run properly.
Connect the remaining wires if you plan to use the onboard diagnostic CONSULT connector.
The Apexi turbo timer is connected to the O2 sensor wire at the ECU to provide auto countdown functions. The Apexi AVC-R is also attached to the ECU harness for tachometer signal, speed signal, and throttle position. Apexi products come with a very good ECU pinout diagram that is extremely useful.
Remove the brackets from the SR ECU to make it easier to mount.
Fuel System & Vacuum lines
Back to Top
The SR20DET uses 370cc / min side feed injectors. Apexi makes 550cc and 740cc injectors for the SR that drop right in. The project car is now using Apexi 550cc injectors in the stock fuel rail with the JWT tuned ECU. Use hi pressure fuel injection lines and good clamps with a new fuel filter to ensure reliability. When attaching the fuel lines, do not mix them up or the engine will not run right. The fuel pressure regulator end of the fuel rail is the return side; do not attach it to the fuel filter, which is the supply.
