S14 SR20DET ECU help
boostedkouki
Car: 1997 Nissan 240sx
I seem to have an Ecu that I can't find a pinout diagram for. I have searched for hours. It is an NB 23710 80F10 A18-F02-G09I have found out it is an ECU for a 97-98 kouki auto which would apply, but I can't find a pinout diagram anywhere. I have found what one would think would apply but the number of pins doesn't match up.I'm trying to wire up my afc-neo but am at a loss. Thanks for any help.
SpeedRacer1
Car: 1990 240SX, G35
The wiring diagram for all Nissan ECU's is in the NEO wiring manual.
boostedkouki
Thanks for the reply, unless your neo wiring manual is different than mine it is not in there. The pin pattern for my ecu is 18pins , 16pins, 14pins and 16pins. from left to right. None of the ecu's in the manual have that pattern. again i do apprecate your help.
Modified by boostedkouki at 3:24 AM 3/5/2007
captainfalco
Car: S14,MX83
On a similar note, does anyone know where to get a zenki "WC" ecu at a sub $400 level? sorry to tread jack.....
SpeedRacer1
Go here, its the AFC NEO wiring manual.Go to page 25, you are using the S14 6/1996-12/1998. ECU terminal drawing N3-a.
Go to page 28 where you will find N3-a. An interesting thing will happen when you take you ecu, and turn it right side up. All of a sudden the pin pattern will go from 18pins, 16pins, 14pins and 16pins to 16 pins, 14 pins, 16 pins, 18 pins, just like the N3-a terminal drawing.
Problem solved, case closed.
http://www.apexi-usa.com/pdfWiring/13.pdf
