sonny1335 wrote:i had the same problems when i switch to iridiums, threw those in the garbage and problem fixed right away. I've herd of some many people that live by iridiums...but i also herd the opposite. btw your afrs at 13 WOT is to lean...............
i actually have to edit that, because i double checked my AFRS i have the AEM UEGO Wideband btw, its weird bro while im driving into boost its 13.X, and when i come to an idle it'll rise up to 18 and then the gauge reads --- its stays at --- on idle the red light is all the way to the bottom. What would cause my car to run so lean? as I mentioned before the injectors are brand new.. My FPR is set to 40psi.
Also does my BCU have any play in this?, the tuner never really was able to diagnose what was really wrong with my car he told me he thinks it might be my boost controller or wastegate... but Idk why that would effect the car at all especially since he "tuned" my car.
(MORPH) Ok will check the gap thanks for advice..
(Lobo240sx)
I do have the stock Garrett T28
** two more things i forgot to add to the list of problems im having, while im at idle i hear small popping kinda like little backfires and i can feel it through the brake pedal ...
Also when i turn on my car for the first time in the day and well most of the time that i start it, the idles jump up and down 800 - 1400 and it will idle like that for like 3mins
