SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Sun Feb 25, 2007 1:16 pm
That wire harness came off of an October 1993-May 1995 MT S14. This means you need a red WC ECU.
To get the date off of the coilpacks look at the tip area closer to where the spark plug connects. You will see numbers and dots next to them. The numbers are either 95 or 5, etc. So for example if the numbers 3 and 4 have 12 dots next to them that means they were in the factory and got stamped 12 times, once each month. Then if the 5 has only 4 dots next to it it means the the year the coilpack left the factory what April 1995. 4 meaning April, 5 meaning 1995.
