hungryjoseph »
https://forums.nicoclub.com/hungryjoseph-u50257.html
Thu Nov 16, 2006 8:20 pm
alright, so i just got the car a few days ago, and i knew i shouldn't have taken the car out until i had everything fixed, but i did. The first time, the temp was at 210, so i put some water in the radiator and it was fine for a while, at 160. Then some benz had to roll up and rev next to me... i was tempted... i mean i knew i shuuldn't have but.. yeah. (i know im probably the dumbest kid alive right now, thats defiantely how i feel) well i killed it, but then i also killed the heat. started gettigna bove 200 again so i put more water in it, and it made it for about 7 miles without any temp problems, then it started going up to 200 again. The coolant started smoking. I parked at a metro station and left the car there. I talked to the station manager and i got permission to leave the car there. So basicaly, the radiator is way to small, but the dual fans should be enough to cool it down... the resevoir is about 1/3rd filled with coolant, and i dont know anything about cars so i dont know if thats how m uch it should be filled, or if i need more. My plans are to have my friend come over tomorow, see if we can get the car to a shop nearby. where should i go from here? should i get more coolant? if so, how much do i fill it up? its idling at 2.5- 3 rpm's right now , but when i put it in gear, it goes back to normal. why is this? any help right now would be appreciated... i'm a major "noobie" and i'm seriously worried PHEW thanks if you read all that!
PS! what are good brands for the sr20? radiator wise, spark plugs, coilpacks, and plug wires?
THANK YOU
